Bi-Wiring Missions
Discussion in 'Home Cinema Speakers' started by -, Apr 3, 2001.
  1. Guest
    Yes you can,
    My old yam 595 had a&b switches. Just connect speaker a output to one pair of inputs on mission and speaker b to the other pair of inputs on the same speaker. Then switch on both a&b speaker outputs on the amp.
    ninc0
  2. slamakn
    slamakn
    My Mission main speakers are capable of bi-wiring. I have a Yamaha RXV596RDS receiver which has A & B main speaker outputs. Can I use both of these to bi-wire my Missions or is it not possible using this sort of setup?
    Any help would be appreciated. Thanks
    NPS
  3. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    Try splitting the wires [hope you are using multistrand cable :)]at the speaker end so that you have 2 reds and 2 blacks, and only use speaker set A.
    Compare this method to the one mentioned above and get back to us.
