bi wiring is there a cost effective way to try this
Discussion in 'Home Cinema Speakers' started by mick23, Jul 30, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    tried biwiring with mordaunt-short ms 540s and 3802 some time ago using bog standard speaker cable about 40pence a meter, could not notice any differance,bought some qed s/aniversary which improved sound, now have bwcdm1nts as fronts,dealer suggested biwiring with dnm reason cable instead of qed s/ann this is going to work out about £100 with termination plugs, cant really ask dealer to make up cables to try, if no real improvment ( dmn or qed) single or biwire) say no i dont want this cable or waste £100 any one got other suggestions
  2. Sly
    Sly
    Apr 28, 2002
    1,519
    west mids,England.
    +52
    phone round your local AV shops cuz lots of them loan out cables to try(with deposit).Even if you could'nt get the exact ones it would give you a idea of if it was worth the extra.
    also i am thinking of bi-wiring but am only able to do fronts,is that gonna be worth it?
    post your results if you don't mind!
    :D thanks:D
