Bi-Wiring front speakers
Discussion in 'AV Receivers & Amplifiers' started by jimthetim, Dec 2, 2004.
  1. jimthetim
    jimthetim
    I have a Yamaha RXV630RDS that i'm considering replacing. It lacks a little oomph for my room which is fairly large. I am considering the DSP AX750. Im not concerned about losing the receiver and i'm quite happy with my current 5.1 speaker set up. Does anyone know if the unused circuits to the additional 2 effect speakers on the Yamaha can be used to bi-wire my front main speakers as with the new too expensive Arcam gear?
    Thanks in advance
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Do you mean bi-amp the speakers
  3. jimthetim
    jimthetim
    yes, i i do mean bi-amp. I was reading that with the new Arcam AVR250 you can reassign the power amps for the rear speakers to bi amp the front channels. I'm kinda new to all this and i just wondered if you could do a similar thing with all 7 channel amps.
  4. Mango Bob
    Mango Bob
    Jan 12, 2004
    513
    16
    London
    The 750 can't bi-amp, only biwire across the A+B posts...having said that, my one sounds lovely in stereo driving a pair of MS906s. I think you need to go up to the 1500 to get bi-amping - but do a quick search for threads about ordering from Germany. I think the 1500 is not much more from Germany!
  5. jimthetim
    jimthetim
    Thanks guys
