bi-wired lg all in one
Discussion in 'Home Cinema Buying & Building' started by pea69, Feb 3, 2009.
  1. pea69
    pea69
    i have found an lg all inone system that has all the features i want:thumbsup:
    but the speakers are bi-wired.
    i wanted to fit the rear speakers to the wires that i hvae been using for my present surround system- it is run under a wooden floor, but i did run an extra set incase i had problems- so for each rear speaker i have 2 wires each with 2 connections- 4 in all
    will i be able to use the bi-wired speakers with my current set up?
    and are th lg speakers pre wired or can i wire them to the wires that i already have?
