--BI-WIRE????????
Discussion in 'Home Cinema Speakers' started by mongo, Jul 20, 2001.
  1. mongo
    mongo
    I HAVE A E-07 AMP AND SPEAKERS I CAN BI WIRE CAN I DO THIS WITH THIS AMP ?>
    GET BACK
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    YES.
  3. KAO
    KAO
    Mongo, yes you can. I have an E07 and I biwire my Infinity speakers from it. The only difficulty is getting the double thickness of cable into the terminals.
  4. mongo
    mongo
    I NO WOT YOU MEAN TOO DAM CLOSE DID YOU SEE A DIFFERANCE IN SOUND ALSO WOT IMPENDANCE ARE YOUR SPEAKERS??
    GET BACK
    THANKS
  5. KAO
    KAO
    Mongo. I have Infinity Kappa 90 floorstanders which I think (I don't have them with me!) are nominally 6ohm impedance.
    I did hear a difference...I thought the sound was a little tighter and more coherent. Difficult to explain, but try it...it's not too expensive to give it a go and you might be surprised.
