Question Bi Wire
Discussion in 'What Speakers Should I Buy?' started by Cwhelan, Apr 20, 2016.
Tags:
  1. Cwhelan
    Cwhelan
    Jan 29, 2005
    148
    Milton Keynes
    Hi all
    Just getting my head around a new speaker package & I have seen a few posts about people Bi-Wire (ing) their speakers. I have no clue what this is!
    Question if I may, what is Bi-Wire? is it any better than just a normal speaker cable connection?
    Apologies for my lack of knowledge!
    Many Thanks
    Conor
  2. PSM1
    PSM1
    Dec 20, 2008
    26,265
    +5,423
    Biwiring does nothing that a decent single cable can not do. If your speaker has 2 sets of speaker terminals on the back then you can biwire which is taking two speaker cables from the one output on the AVR to the 2 sets of connections on the back of the cable. This effectively gives you a larger cross sectional area of copper to the speakers which can be achieved with just a single cable or decent thickness.
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    21,809
    +4,069
    I have Graphics -
    [​IMG]
    [​IMG]
    If you have spare wire laying around, give Bi-Wiring a try, experience is never wasted ... just don't expect much. There is some pseudo-logic to explain Bi-Wire, but there is really very little evidence that it does anything.
    Steve/bluewizard
