Bi Wire volume loss on Denon AVR 2313
Discussion in 'AV Receivers & Amplifiers' started by RichardReid, Feb 7, 2014.
Tags:
  1. RichardReid
    RichardReid
    Feb 7, 2014
    2
    I'm a new member so excuse me if this question has been answered before or is possibly obvious. I have a Denon AVR 2313 receiver. I had up until recently bi- amped my paradigm monitor 7 floor standers using the surround back outputs as described in the denon manual. I only run a sub, 2x mains and a centre. I recently chose to add two PSB CS1000 outdoor speakers using the zone two option. Denon advise using the assignable surround back outputs so I put the paradigm mains back to standard non bi-wired set up. I have noticed a considerable reduction in volume on the main speaker set up at the same volume setting on the main channel. Zone 2 works fine. I used to watch tv at the 30 volume setting but now have it at 50 on the arvo for the same volume?
    Is this to be expected ? I would not have expected so much loss in power ?
    Regards
    Richard
  2. dante01
    dante01
    Mar 5, 2009
    46,154
    +11,062
    Try running the Audyssey set up again.
  3. stevelup
    stevelup
    Aug 13, 2002
    6,795
    Swindon
    +1,300
    There shouldn't be any difference at all. Something odd has happened here. Are you positive you haven't perhaps wired one of the front speakers out of phase when you remade the connections?
  4. RichardReid
    RichardReid
    Feb 7, 2014
    2
    Thanks Dante01. I ran Audyssey as advised and it fixed the problem.
    I assume that the avr outputs greater power to the front mains when not in bi-wire configuration as assignable surround back powering also in biwire configuration. Not that it now matters as Audyssey test fixed the problem.
    Thanks also Steve for your input.
  5. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    You mean you have biamped your fronts not biwired which is a different thing entirely.
  6. Gary Chong
    Gary Chong
    Apr 25, 2014
    2
    Hi Guys
    Just wanted to know if I can connect the denon 2313 to a set of bose cube speakers?
    Thanks for any replies that may come.
  7. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    Yes you can but unless you already have the speakers then I would buy something else instead.
  8. Gary Chong
    Gary Chong
    Apr 25, 2014
    2
    Thanks PSM1. Yes, I actually have a set of Bose system but now the music center is out. As for the Accousticmass, I cannot hook it up to any amp, right? Therefore, now I need to get an amp and sub to hook it up to the cube speakers but not sure about the sound quality. Is this the best option for me????
