Bi-wire using A + B Outputs?
Discussion in 'Home Cinema Speakers' started by AndyDD, Oct 20, 2003.
  1. AndyDD
    AndyDD
    Aug 28, 2002
    88
    Newbie type question...
    I want to try bi-wiring my front speakers to see for myself if there is an improvement. I have enough spare cable to do this.
    My current amp is a Sony DB830. This has Front A (L/R), and Front B (L/R) outputs. Also have a switch to select A, B, or A+B.
    Should I connect each of the two sets to a single A, or use the A and B outputs for each crossover? The speakers are 773s.
  2. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    I use both A+B outputs for bi-wiring on my NAD C370. Minor nuisance is that when you turn it on, it defaults to A alone. Having said that, I've gotten into the habit of leaving everything on, so it's no big deal.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Either will do, A and B perhaps is easier since you won't need to squezze two cables into one terminal.
  4. AndyDD
    AndyDD
    Aug 28, 2002
    88
    Managed to get some banana plugs from work, cut my spare cable (some cheapish QED stuff) to the same lengths....
    I had a good listen to some Groove Armada. Added the extra set of cables and listened again to the same music.
    Wow!!!
    No difference :blush:
    I can understand the theory why it might work.
  5. Radioactive__Man
    Radioactive__Man
    Jan 13, 2001
    967
    Scotland
    +18
    on the basis that you really didn't hear any difference, did you remove the link wire/plate from the speaker terminals 1st ?
    apologies if you already did the obvious:lesson:
  6. mr_blah
    mr_blah
    Sep 24, 2003
    39
    9
    Could the same idea work for a Center speaker using A+B instead of just using A?
  7. AndyDD
    AndyDD
    Aug 28, 2002
    88
    I indeed removed the shorting plates. It is possible that my amp isn't of enough quality to show the benefits. I'm running a Denon 2900, with the 6 analogue inputs using QED 2's 0.5 metre interconnects so my source should be OK. I wasn't really upset with the CD strereo quality anyway, although using the digital input is a bit better. My other speakers aren't bi-wirable but I've run out of spare cable anyway.
    I'm trying to decide between a Pioneer AX3 or a Denon 3803, but that's another thread :)
  8. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Personally I haven't heard my system with anything but biwire, but I don't think you'd be the first to say they can't tell the difference. ;)
  9. YS-YS
    YS-YS
    no there is really no arguement to bi-wire, and for a true bi-wire you, take out the bridge on the speakers. then connect both pairs of wires to the same connector on the amp, either the A or the B.
  10. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Biwiring has as many detractors as it has supporters so please don't state your opinions as if they were facts.
  11. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    On most amplifiers the A/B switch simply parallels up the speaker outputs so in fact you are actually using the same connector just inside the amp.:rolleyes:
    IMO bi-wiring is more dependant on the speakers than the amp, I found my 603’s a bit sibilant with some music Bi-Wiring solved this, they are now bi-amplified now that was a difference. :smashin:
  12. YS-YS
    YS-YS
    yes some amps are like that. :rolleyes: but not all.
    Ian J - would you care to show me an argument that stands up.
    if so I will never post such a statement about bi-wireing on any forum again.
    over to you.
    YS-YS
  13. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    There is only one valid argument and that is people's ears and as there are a great many people that state that biwiring makes no different, your bald statement that "no there is really no arguement to bi-wire" is patently untrue. There are many threads within this forum (and others) about the subject including one here and another here
  14. YS-YS
    YS-YS
    I accept you cannot tell people what they hear, but for all of you watching I ask for you to try blind tests, knowing there is a difference and trying to find one will always succeed. but if you dont know what the speakers are wired up with that would be the real test.
  15. pwiles1968
    pwiles1968
    May 15, 2003
    773
    +9
    Yes I know, some of them have separate amplifiers for A & B, in which case you would be Bi-Amplifying the speakers, BONUS. :D.
    I trust my ears and I felt Bi Wiring helped with my B&W's. Not saying it would help with all speakers and it may just have been the reduction in impedance but IMO there was a difference.
  16. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    If you have a Center A and B out (some e.g. Yamahas do) and the speaker can be bi-wired/amped, then yes.
  17. mr_blah
    mr_blah
    Sep 24, 2003
    39
    9
    Yeah thanks, i have a yamaha DSP A1 - soon to be Z9 :)
    So the Center KEF TDM23c will be getting hooked upto A+B then, even if its not a bi-wire speaker.
  18. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Why would you want to do this then? Doesn't make sense IMO ...
  19. mr_blah
    mr_blah
    Sep 24, 2003
    39
    9
    Well i don't see the harm, but have had the KEF Q75's bi-wired (now tdm23f) from the amp cause the q75's allowed this and to keep all the speaker cabling same lenths and amount, i left the center speaker like the ex-main fronts bi-wired, yes i know it really needs a amp that can do this, so it isnt about cost or a waste, but it might make a difference.
  20. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    No harm but effectively you are doubling the diameter of the speaker cable, so there should be a difference - most likely more bass (not necessarily "better" bass).
