Bi wire speakers for Cambridge AV receiver
Discussion in 'AV Receivers & Amplifiers' started by scottyfox, Sep 24, 2004.
  1. scottyfox
    scottyfox
    hello, i have qed silver an cable with bi wire facilty on my mordaunt short speakers. I have the cambridge azur 540 r reciever, but there is not enought holes for the connections, lol.
    What can i do?
    needless to say i am new to the game, apologies for my ignorance!!!
    any advice would be appriciated.
    scottyfox
  2. Vodder
    Vodder
    Jan 11, 2004
    443
    16
    London, UK
    As I understand it you your amp doesn't have separate connections for bi-wiring then you just feed both sets of cable into the single plug.
  3. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Fret not sir, all is not lost.
    In order to biwire your MSs, you need to have only two plugs at the amp end of each speaker cable with two runs of cable into each plug, and four plugs at the speaker end, with only one run in each. Hard to explain maybe without a picture, but you're making a Y configuration so that one plug goes out to two plugs. Or, if you have bare wire cable with no plugs, just wrap the ends of two + cables round each of the red terminals and two - cables round the blacks, and then one + to each red on the speaker, and likewise with the black. DO NOT LEAVE IN THE JUMPER BARS THAT CONNECT THE SPEAER TERMINALS ON THE SPEAKER!!! YOU WILL BLOW UP YOUR AMP!!! :suicide:
    AMP (+) o-<=========8 (+) SPEAKER
    (-) o-<=========8 (-)
    Hope that makes sense. Maybe someone else can explain it better.
    Mike
  4. scottyfox
    scottyfox
    what are the jumper bars?
  5. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    A very good question. I've not seen the back of your speakers, so I'm only guessing here, but usually, the terminals are joined by a small piece of metal, so that the two reds are linked, as are the two blacks. This is so that if you only want to single wire them, you just use a single run and stick it into either set. However, if you do biwire, then you'll be using the terminals independently, and will not therefore be using this piece of metal. If it is there, you must remove it otherwise you'll short you amp and potentially fry it. Usually the terminals unscrew slightly so you can slip it out from under them. Keep hold of it for future use/sale.
  6. scottyfox
    scottyfox
    many thanks kind sir!
