memphisuklf
Established Member
Does it matter what direction you use your speaker cable. My friend has just set he's up and asking for advice.
He has set up his system and bi-wired his speakers but his speaker wire is directed from his speakers into his amp.
What I have read is that speaker cable should be pointed away from the amp and into the speakers.
Any difference/Benifits in which way you do it as long as they are in the right connectors?
