Bi-Wire question
Discussion in 'Home Cinema Speakers' started by CodeThief, Jun 4, 2002.
  1. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Hi there,
    Is it best to wire with one long run thats jumpered or two long runs to each speaker??? Am I right in assuming that the amp is looking for a return from each driver and keeping these seperate is what causes the sound quality difference??? Please see attached bad pic for an example of what Im blabbering on about!!
    Dave
    [​IMG]
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,496
    Its worth doing a search in this subject as it has come up a number of times, some people prefer it, others dont, some say it improves sound quality, others dont etc etc
    Its also been an argumentative subject!!
    The best thing you can do is try for yourself and see what you think.:)
    cheers
  3. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Thanks for the reply,
    I'll go search now (sorry) :)
    Dave
  4. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    Based on your diagrams, the first is not really bi-wired. It is effectively the same as single wired speakers with bridged speaker terminals. The second looks like bi-wiring assumming the cables are twin core ie each has positive and negative runs. You're right, your diagram could be better.
  5. Garrett
    Garrett
    Apr 21, 2001
    43,243
    2
    167
    The best thief you'll never see.
    +8,174
    One thing I can assure you on is Bi-amping makes a difference.
    As to your question, is it possible to try it with the speaker cable you have at present on one speaker?
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I agree, the first one is single wired. However some peple recommend replacing the metal links with two (short) jumpers instead - supposingly improving the sound. But it's not called bi-wiring then.
    No, the amp will not "look for a return" and neither do low frequencies flow in the high path nor a high frequency in the bass/mid path. As well they do not just "dissappear" (e.g. as heat).
    Instead the 'opposite' frequency will be blocked by the x-over components in each path.
    This results in a seperation of the low and high frequencies over the entire cable length which theoretically gives a better sound. At least so some people claim.
    Opinions on this are however very much divided and some speaker makers don't even support biwiring like e.g. Dynaudio.
    Which really leaves only one thing to do: try yourself and see.
    You may also consider just doubling the diameter (without opening the link at the speaker terminals), I would be interested in any opinon comparing bi-wiring vs. increased diameter (using the same cable).
  7. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    LOL!!
    Thanks for the replies all, sorry about the diagram >.<
    Hmm reckon that I better get a demo of the Q1s bi-wired and not, could save me £50 in cable (unless I go the CAT5 route ;) )
    Dave
  8. Dominic
    Dominic
    Mar 2, 2001
    289
    Essex
    +6
    its been said that Bi wire is a typo on the manufacutures specs and should have been
    buy wire
    :D
