Bi-Wire Cable Question
Discussion in 'Cables & Switches' started by TurnipFarmer, Mar 26, 2005.
  1. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    I have just got some speaker cable with banana plugs. 4 that go to the speaker which fit fine and 2 that go to the amp but me being stupid didnt relise that my amp does not allow the use of banana plugs, would I be able to cut these banana plugs off to use as bare wire?
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    Should not be a problem
  3. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    thanks for the help
    however before i do that, i need to find out if there is a way of connecting my marantz pm7200 using banana plugs that i havent worked out, see my other thread for that
  4. gerbilly
    gerbilly
    Mar 20, 2005
    2,182
    Hamilton
    +94
    Mate your Marrantz does accept Banana Plugs, I have the 4400 amp and with that if you get a needle and press gently into the speaker connections the small plastic bit in the centre should come off.
    Make sure it isnt plugged in first.
  5. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    thanks for your help
    you sure that the 4400 is the same as 7200?
    does it reveal a 4mm hole if i get the cap off?
  6. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    Look at the binding posts. If they have what looks like a cover in the middle then try removing it with said pin.
    Fish
  7. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    just looked cant see anything like that, tried unscrewing the caps and they just get stuck so far. All mine seem to be is a cap stuck on a binding post that screws into the back of my amp, if anybody can send me a pic to show me how its done it would be great help
  8. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    OK just checked Marantz's website, and they describe the speaker terminals as screwed. Link
    [​IMG]
    Fish
  9. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    Thanks fish
    does that mean because they are screwed i cant use b-plugs?
  10. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    233
    You could use them if they fit in the holes on the binding posts, where the cable would go.
    Fish
  11. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    The PM7200 will definitely accept 4mm plugs. You will have to remove the black plastic plugs (caps) which are fitted in the end of the screw terminals. You can clearly see them in the picture above. They can be removed very easily with your fingernail or a penknife. Prise them out to reveal the 4mm socket.
  12. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    Il give it a blast, as long as i can put them back on if need be and it wont break me amp, are they only fitted onto the post and not glued or screwed on?
    i think i see what you guys mean now
    sorry for being such a idiot
  13. TurnipFarmer
    TurnipFarmer
    Mar 4, 2005
    1,240
    38
    Hertfordshire
    +5
    got it working i was looking at something completely different at the back, bet u guys were thinks that im well thick, when i worked out it was the black caps in the middle of speaker terminals i was like 'WHAT A DIV' lol
    anyway cheers for your help guys
  14. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    :smashin: Easy when you know how
