bi-wire adaptors
Discussion in 'Home Cinema Speakers' started by ianlecompte, Nov 24, 2003.
  1. ianlecompte
    ianlecompte
    Sep 17, 2002
    954
    oxfordshire
    +13
    just seen some of these on e-bay,can i make my own with a short length of cable?do i run the main cable in the top or bottom terminals?.this would be good if i can because i cannot accomadate two cables in one terminal on the amp end because they are stupid spring clips.
    p.s would this be worth it,speakers are b&w 601s,and would it be the same as running two cables as you would for proper bi_wiring?any advice most grateful.
