Bi-polar surrounds and multi channel music
Discussion in 'Home Cinema Speakers' started by anderson64, Sep 30, 2004.
  1. anderson64
    anderson64
    Dec 11, 2002
    29
    I am about to upgrade my dvd and amp to the 575a & 750se, with a view to listening to more music, especially so in multi channel & or pl11.
    Am I correct that I will need to change my bi-polar surounds to normal speakers to get the best from the system?
    I currenly have Kef Q35s & a Q95 centre as the fronts, other than the obvious Kefs, any recomendations for reasonably priced speakers as replacements?
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    You dont have to replace your bipolars just because you wan to listen ot multichannel music. They might not be quite as good as direct firing ones but i dont have anyproblems with my ht2bps with dvd-s or using NEO:6music.
  3. Antpink
    Antpink
    Jan 18, 2004
    468
    43
    Singapore
    +100
    Check the specs on the 750, if I am not wrong, you can wire 2 different types of rear surround speakers to two different (A and B) speaker terminals on the back of the amp, and have the amp select A (say) for movies and (B) for music. Means you would have to add a pair of speakers though, which might start making people (in my case it would be the wife) a bit concerned when she comes into find a full 7 speaker system comprising 9 speakers mounted all over the room!!
  4. anderson64
    anderson64
    Dec 11, 2002
    29
    :clap:
