Bi-Polar Blues.....:(
Discussion in 'Home Cinema Speakers' started by EmissarY, Jul 31, 2001.
  1. EmissarY
    EmissarY
    Hi Everyone,
    I have a question that has been worrying me over the past few months. You see I bought a set of speakers for my modest HC setup:
    Eltax Symphony 6.2
    Eltax Symphony Centre
    Mordaunt-Short Bi-Polars (rears)
    All linked to a Pioneer VSX 709 RDS reciever.
    My room is a square in shape, so if u can imagine it forms the 'typical' surround sound diagram...my worry however, is with my bi-polars. I have them set on typical speaker brackets that are bolted to the wall approximately 2-3 feet above ear level. A few months ago whilst watching a dvd (Next Friday)I was alarmed at the distortion/rattle coming from them. It sounded as though they had blown. How can I know if they have blown for sure? Do i have them set up correctly? What direction should they be pointed towards?
    My cabling is half decent oxygen free stuff but what would sort would be better for this setup?
    Thanx, for listening,
    Can somebody enlighten me please?
    Emissary. :( :( :(
  2. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    hiya are you sure its the speakers and not the brackets or even the plaster board ?
    try using them on the ground or speaker stand to test them ...i used bypole speakers "definitive technology "and the back of them are about a foot away from the wall and i get great separation sound ...
    not sure this is much help tho ..
  3. EmissarY
    EmissarY
    Thanx, Leon <img src="wink.gif" border="0"> ,
    Will try those methods u mentioned. Particularly putting them on the floor. Also, i didn't think <img src="rolleyes.gif" border="0"> about the plaster board either, and the speaker brackets are actually mounted on a plaster board wall....just have to keep experimenting i guess...
    Thanx 4 ya help.
    P.S. Congrats on the HomeCinemaChoice article pic. Your star is truly shining....very <img src="cool.gif" border="0">
    Laters. EmissarY.
  4. leon
    leon
    May 15, 2001
    1,158
    kent
    +67
    no problem <img src="smile.gif" border="0"><br />i had the same sort of problems a while back made the wall vibrate like a good en <img src="smile.gif" border="0">
