Bi-amping with two Arcam 8Ps
Discussion in 'Arcam Owners' Forum' started by riverrun, Sep 18, 2004.
Tags:
  1. riverrun
    riverrun
    Jul 4, 2004
    37
    I'm presently biamping my speakers with an Arcam 8 (integrated) for HF and an 8P for LF. If I had another 8P, and use one to drive HF and the other for LF could I use the integrated amp to control them or would I need a pre-amp instead?
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    Yes, just run the preouts from your integrated amp to the first 8P then from that to the second 8P.
  3. riverrun
    riverrun
    Jul 4, 2004
    37
    I didn't realise it was so simple, thanks. Do you know how you would use the mono link sockets in a set-up like that (one integrated amp plus two power amps)? Do you think adding a second power amp is worthwhile?
    What's your opinion of the MF A308?
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    In a mono setup you would connect the integrated amp to the tweeters on your speakers and then run the left preout to the mono amp connected to the left speaker adn the right preout to the mono amp connected to the right speaker.
    I really like my MF A308, hugely powerful and yet beguilingly musical at the same time. I am hankering after their new KW500 amp and so I have my A308 up for sale at the moment for £1200 in mint/new condition with all packaging and accessories. The A308 would annihiliate your Arcam amp for control and transparency. If you are interested then PM me.
    Chris.
  5. riverrun
    riverrun
    Jul 4, 2004
    37
    By using the RCA sockets labelled Mono Link?
    Using a single run of IC between the integrated amp to just one of the Power Amp In sockets of a power amp, with the U-link in place?
    An MF amp is long term and then more likely older models. But you never know.
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    Yes, just a single RCA to RCA cable from preouts on the integrated amp to the input on each mono amp.
  7. Miron
    Miron
    Sep 26, 2002
    1,408
    Vienna, Austria
    +49
    Crusty, what's price tag for KW500?
  8. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
  9. petrus
    petrus
    any significant difference between fmj cd33 and diva cd192? cause the spec looks only slightly different
  10. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,499
    Edinburgh
    +1,236
    The CD33 is a bit more detailed and a little bit more articulate than the CD192. It's also built a lot better. Major hardware differences are the chassis which has very good dampening properties and the separate power supplies for each section which reduces the noise floor even further.
