Bi-amping with a Rotel 1075 possible?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by Fishbones, Aug 25, 2006.
  1. Fishbones
    Fishbones
    Jan 26, 2004
    127
    Madeira
    Hi as per title....is this possible? I can think of using a Y-splitter for the inputs, but is this OK impedence wise :confused:
    The Arcam P1000 does this job beautifully.
  2. inzaman
    inzaman
    Dec 16, 2002
    8,001
    Derby
    +1,065
    Cant see why it wouldn't work the same with the splitter, unless there is some technical issue. This is what i do with my Rotel 985MkII to drive the front L/R.
