Bi-amping speakers (Denon 2807)
Discussion in 'AV Receivers & Amplifiers' started by jwyg, Feb 4, 2009.
Tags:
  1. jwyg
    jwyg
    Jan 16, 2009
    373
    +8
    hi, i've recently bought a 2nd hand AVR2807 and some tannoy F4 speakers. reading the manual, it appears that i can bi-amp the front speakers on a 5.1 set-up by using the surround rear outputs (at least i think it was surround rear, i got a bit confused by the front A+B thing)
    However, it mentions nothing on the manual about which speaker outputs should go to the high frequency input on the speaker, and which to the low - or does the amp not split high and low frequencies?
  2. Peter Galbavy
    Peter Galbavy
    Doesn't matter. The frequencies are "selected" by the speaker / high and low pass filters in the speaker.
  3. jwyg
    jwyg
    Jan 16, 2009
    373
    +8
    ok great cheers - asking as with my audio amp i could bi-wire and this split high and low freq's but i'll be replacing this with the denon.
