Bi Amping on Yamaha RX650
Discussion in 'AV Receivers & Amplifiers' started by easyrider, Jul 24, 2005.
Tags:
  1. easyrider
    easyrider
    Hi, Ive got a Yamaha RX650 which is a 7.1 ch amp and the fronts are split as A/B channels but can be both turned on/used at the same time.
    I was wondering if it was possible to use these channels to bi amp a speaker using these channels or even using the real channels.
    I am currently using Monitor Audio B6 speakers, and do not plan to use any of the other channels for a while.
    Ez Rider
