BI-AMPING Marantz SR 7011
72 B50 MX
Bi-amping Marantz 7011 front speakers. It’s working but my surround back speakers have gone silent, not playing audio on multi-channel stereo.
7011 manual says: “7.1ch (Bi-Amp):
Setting to assign the power amplifiers in this unit for front speaker bi-amp connection to 2-channels.
You can connect speakers for up to 9.1-channels for MAIN ZONE.”
Anyone know how I can continue to bi-amp and output audio to all channels, including surround back speakers?
Marantz Support (MS) told me I had to choose between 7.1 bi-amp or 9.1 — 7011 can’t do 9.1 bi-amp, can only do 7.1 bi-amp.
MS said I have to buy $3400 8015 to get 9.1 bi-amp. True?
goingoingong
SR7011 has 9 power amps so can only do 7.1 biamp. 7 + 2 for biamp=9.
9.1 biamp needs 11 power amps. 9 + 2 for the bi-amp=11.
SR8015 has 11 power amps so can do 9.1 biamp.
John7
My Pioneer LX701 is the same.
I wanted to bi-amp the fronts and retain the surrounds. Luckily the front L/R pre-outs are active permanently. I hooked up a power amp to the pre-outs and connected the outputs to the HF terminals on my speakers. The Pioneer drives the LF speakers
The Power amp (an XTZ A300) has an adjustable gain control on the rear which I used to balance the audio between LF and HF. Works well for me.
Alos, I wanted to have the surround back rears active (the Pioneer is only a 9 channel amp) so I added a Tibo PA150 to the SB pre-outs, so now I have a 7.1.4 system
Podcast: Best Home Cinema Sources and B&W 805D4 Speaker Review and more...
