Bi Amping Denon 3805
paulcollins14
I have searched through this forum thinking I could find the answer to my question but not so far.
I want to Bi wire my centre channel speaker, the front 2 channels on my receiver are not used as the fronts are connected to my Cyrus hifi. How do I assign the front channels of the Denon receiver to centre channel duties?
Sorry if this question has been asked before.
Paul
Jase
You can't, basically. There's a workaround to use the Surround Back amps to Bi-Amp the Front Left and Right channels but that's about it.
jensK
Paul
One way of bi wire your centre speaker is to buy a mono power amp with two outputs for bi wiring and connect the power amp to your pre-out (this based on the assumption that the 3805 amp has centre pre-out/ there is a pre-out on my 3806). Obviously you have to invest in an additional mono amp. Which is the downside of this solution.
Mr Incredible
I know this is an old thread, but hey, what the heck!!
I think the workaround for bi-amping the front L+R could be modified to provide bi-amping duties for the centre.
In the well publicised 3805 bi-amping workaround, the rear surround amps are assigned to Zone 2 (or 3) and the Main pre-outs are used as an analogue input to the VDP (or any other free analogue input really) and VDP selected as the source for the Zone 2/3. The surround amps then power the left / right speakers as well as the main amps L + R.
Now instead of looping the mains pre-out L+R to the left/right analogue input on the VDP, you take the centre pre-out and split it into the L/R input so they get the same (centre) signal. You can then use Zone 2/3 to bi-amp the centre speaker. Voila! Problem solved. I think!!
