Bi Amping Denon 3805?
Discussion in 'AV Receivers & Amplifiers' started by JetJockey, Dec 8, 2004.
Tags:
  1. JetJockey
    JetJockey
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,739
    London
    +1,075
    Be careful when bi-amping the denon 3805, it has not been designed with this feature in mind and therefore you should proceed cautiously.
    If your front speakers are of reasonable quality then bi-amping is definitley worth it. You may be better off buying a separate power amp if you're seriously thinking of bi-amping though.
  3. JetJockey
    JetJockey
