Bi-Amping - blown tweeter
Discussion in 'AV Receivers & Amplifiers' started by DeafPhil, Aug 30, 2005.
  1. DeafPhil
    DeafPhil
    I have Denon AVC-A11XV in use with a pair of Mordaunt Short 908 speakers. The AMP is supposed to kick out a maximum 140w per channel and the speakers have an RMS rating of 150w.
    I have used the speakers for quite a while and are well worn in but one of my tweeters has completely stopped working :oops: . My question is, if you bi-amp your speakers would that be 2x140w going to the speakers or still only 140w?
    I do like to turn up the sound quite loud but don't particulary think I went overboard, there was absolutely no distortion and they sounded great. But I went to use them the other day the tweeter had completely stopped working, the only thing I had changed (apart from my amp which was a Yamaha AX750es) is to bi-amp the speakers on the new Denon Amp.
    Any advice / help would be appreciated (except keep the volume down, Ive learnt that lesson already!)
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,461
    United Kingdom
    +1,915
    Bi-Amping will be feeding each speaker 2 x 140w. 140w for the tweeter and 140w for the mid/bass. Obviously that would be MAXIMUM output.
    Replacement tweeters usually aren't that expensive and most can be easily changed. Best have a word with Mordaunt Short and ask them to send one out to you. :)
    Then keep the volume down!
  3. DeafPhil
    DeafPhil
    Thanks for clearing up the bi-amp confusion Jase,
    I contacted the spares supplier this morning and it's £33 for a new tweeter including delivery, so it nots going to break the bank luckily
    And yes I will keep the volume down in future
