Bi-amping AVR100
Discussion in 'AV Receivers & Amplifiers' started by gilck1, Dec 8, 2004.
Tags:
  1. gilck1
    gilck1
    I currently have my system Biamped with AVR100 running the Mid's and a P75 on the High's for two channel - Looking at upgrading to a P85/3 - currently center is bi-wired. Is this worth the upgrade for HT (do listen DVD-A as well)
  2. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    I'm now running a P25/3 with my AV300 driving the LF not the HF. My understanding is that this the best way round to do it. If you switch out the P25 there doesn't seem to be much work for the amp to do showing most of it seems to be done by the power. I run all 3 L/C/R biamped as this is where most of the action takes place and it does sound very very good.
