Bi-amping and Gain..
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by saibot, Mar 1, 2005.
  1. saibot
    saibot
    Jun 28, 2004
    1,240
    Near the Lee - Ireland
    +42
    I've got a marantz 6200 and rotel 985mkII, looking for some advise on bi-amping. A simple soultion would be to biamp fronts and also drive the centre speaker from the 5 channels in the rotel.
    Or, would it be possible to drive LF channels on speakers with rotel and hf's through the marantz, question then is , If there will be a "gain" issue. I've done some searching and cant find what the "gain" of these boxes are. Can some-one tell me where I could find this info ??
    ta,
    d...
  2. Steve Collier
    Steve Collier
    May 2, 2002
    46
    If you can find the specs for them, and they quote what the output voltage is for full scale input then you can work it out yourself.
