Bi amp
Batfoon
Hi.
Total novice so please be gentle. Nice short words please.
I have a Cyrus 8vs, CD8x and a PSX-R. All oldish. I have been given a Smartpower amp and was wonder what connectors from the VS to the Power amp and which unit should i plug the PSXR into to to get the best out of the set up intil i can afford a other.
Hope that makes sense.
Paul7777x
Hello and welcome sir.
The PSX should always go to wherever the preamp section is. In this case the 8VS.
Connect the Smart powers left/right inputs (making sure that the switch is set to stereo) to the preouts on the VS, and off you go.
Paul7777x
You’d need to spend a bit to ‘better‘ your speakers sir.
But taste is a different thing.
Is there anything about them with which you’re unhappy?
Batfoon
Not really. I like them and they punch out a good sound in not a particularly large room which has always been my problem. Im hoping the added amp may drive the speakers better. Currently bi-wired with Chord Rumour 4 cable
Paul7777x
Bi-wiring is at best a waste of cable. It doesn’t do anything.
Bi-amping is a different beast altogether.
You should get a better controlled speaker, especially at high volumes and heavy ohm loads.
Batfoon
Hi.
Another question and again excuse my ignorance.
Speaker wire to the 8vs and Smart amp.
From the 8vs - top 2 Speaker outs to the top terminals on the Speaker and from the smart - bottom 2 terminals on the same speaker.
Is that correct. Or do you suggest a better method 🤔
