I have to disagree with deadringers.
Your Centre speaker or Centre stage plays approx 70% of movie soundtracks, it is the most important speaker when watching films etc
The first thing I done was to adjust the Db's on my system/speakers when my 2 main speakers were getting twice as much power, it still didnt sound right.
I have bi-amped & tri-amped all my speakers, & yes it is far better. I now use mono amps for each speaker but this is because I use chord signature speaker cable (expensive to tri-amp)
I strongly believe that all 3 front speakers should recieve the same power, when you get into a high end system, wrong lengths of cable & less power to certain speakers is very noticable & off putting.
But deadringers & ResidentDeagle are spot on if its bi-amping for stereo sound, just depends if you watch more films than playing CD's
Cheers, Jonny
