Bi Amp question
Discussion in 'Arcam Owners' Forum' started by newbie265, Dec 17, 2004.
Tags:
  1. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    Sevenoaks are installing my system(below) on monday was wondering would it be better to bi amp the two channels not in use on the AVR300 to the fronts or bi amp using the P80?
  2. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    I'd suggest you initially try bi-amping with the P80 for the low end and the AVR for the high end. Then swap them over. Then try bi-wiring with the P80 only.
    And see which you prefer - the changes are only matter of moving the speaker connections at the amps so very easy to do.
    Then let us know the outcome as I'm looking at a similar set up (though with P90 rather than P80).
  3. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Yes would agree with davehk. The seperate power amp makes a difference.
  4. Hifi addict
    Hifi addict
    it also could well be that bi-amping with your AVR300 alone will give a much better integrated sound, then with 2 different amps
  5. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I don't bi-amp, but do use external amps to power my speakers (Alpha 10, Alpha 10P/3, Alpha 9). The sound quality is much better and I can drive my Dynaudios to considerably louder levels.
    It's not that the AVR300 amp section is bad, but you can get substantial improvement with high quality external amps, bi-amping or not.
  6. barnythebear
    barnythebear
    Jul 6, 2004
    152
    leicestershire
    Started off using the biamp option on the 300 but adding the P25/3 made a hell of a difference. Less work for the 300 to do seems to run cooler as a result.
  7. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    Ok cheers guys will experiment tommorrow. :thumbsup:
  8. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    Thats what the sevenoaks guys did and I'm more than happy with it.The cd73t sounds great. :thumbsup:
