Bi amp or 7.1
Discussion in 'AV Receivers & Amplifiers' started by philthyanimal, May 18, 2005.
  1. philthyanimal
    philthyanimal
    What would i benefit more from, bi amping my front Q1's or going for a 7.1 set up?
    Can the 6 & 7th speaker be set above pointing down? or do they need to be behind?
  2. fogster74
    fogster74
    May 17, 2005
    36
    +6
    I suppose it depends on whether you're more interested in movies or music.
    If movoies, then a decent 6.1 / 7.1 set-up is mind-blowing compared to a 5.1 system (I've just upgraded to 7.1 and the result is awesome).
    However, if you watch movies very occasioanlly and like your 5.1 set-up, then I suppose bi-amping the front channels would be the way to go...
    However, on the whole, I would say you get a far more noticeable change and far greater utility in going to 6.1/7.1 than bi-amping......
  3. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Yup go for the 6.1 + and then get a seperate power amp, rotel, arcam stc and bi amp the fronts with that. External amp is better to bi amp with than the internal amps as it releases more power to the other channels on the reciever
  4. Ambient Fish
    Ambient Fish
    Apr 28, 2005
    1,638
    Wishaw
    +225
    Dfour and Foggy have got it right, 6/7.1 is a huge improvement over 5.1 systems, I could not believe the difference it made when I upgraded to my current amp with 7.1 output and Dolby Pro Logic IIX, your CD collection gains another new lease of life and DVDs just dound more solid in 7.1.
