BG808 not showing computer boot
Discussion in 'Projectors, Screens & Video Processors' started by tryingtimes, Jan 6, 2002.
Thread Status:
Not open for further replies.
  1. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    I guess this could be a graphics card problem but just in case it isn't I thought I'd post here.
    My BG808 says 'no signal' while the computer is booting and doesn't let me see the bios or safe mode options. The only time it shows a picture is when the desktop appears! (and then changes memory block once powerstrip kicks in)
    I was going to have a rummage in the bios but even though i'm sure I'm in there it doesn't display anything.
    Any ideas?
    Regards
    Alex
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm fairly sure this is a +ve sync issue which the 808 can't handle (808s does)
    I take it you have still got the Extron grey box plugged in cos I haven't made your cable up yet. but this should automatiocally sort out -ve an +ve sync.
    Try pulling the lead from vertical output of the extron box. If that doesn't work try both hand v leads off and select input 4 on your projector (sync on green).
    After that you'll need a monitor.
  3. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Cheers - I'll give that a try tonight.
    I was thinking that this might have started after your last visit and that would make sense as one of the sync cables was definitely out before.
    I shall report back (I'm going to have to do a full format and reinstall over the next couple of evenings)
    I have a monitor just in case!
    Alex
  4. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Yep - sorted it, thanks
    I can now see my boot and bios in all their resplendent ugliness!
  5. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,329
    Berks, England
    +152
    Alex,
    Well now you can turn the contrast way down (in that memory block), so when the boot text appears, you'll hardly see it!
    I only turn the contrast back-up if I you need to, say to do a ghost disk image backup.
    regards,
    Rob.
  6. tryingtimes
    tryingtimes
    Feb 15, 2001
    4,094
    +531
    Good tip Rob - I'll give that a go, once I've stopped fiddling!
Thread Status:
