BFD part 2
Discussion in 'Home Cinema Speakers' started by petrolhead, Nov 24, 2003.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    This is a big learning curve and after listening to what you guys have said decided to start again
    [​IMG]
    This time the Processor is set to PLII + THX as suggested.
    If you can be bothered I would appreciate some ideas as to where to start.
  2. codling
    codling
    Jul 5, 2001
    427
    hartlepool
    +15
    try for now
    freq= 40hz
    bw= 20
    gain= -12
    i would post a pic of my results but i dont know how to:confused:
    carl:)
  3. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    Results to date
    [​IMG]
    These were the filters I used
    [​IMG]
    The little hump at 40htz is a pain but to get rid of, seems more trouble than it's worth. I tried adding an extra filter at 40htz, 5BW and -5GAIN but it created an unusual drop at 50htz
    This http://www.pellis.co.uk/progs/mine.zip was the spreadsheet that helped to get the results
  4. Ryan
    Ryan
    2 points petrolhead.
    1. Your bandwidths are much too high. Try and keep them narrrow.
    2. where is you LFE cutoff. If it's at 80hz then you shouldn't need to have any settings over 80hz.
  5. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    Petrolhead - Yesterday I got isolation platforms for my sub so I started the BFD process from scratch and documented it with pictures etc, it'll be ready for viewing today hopefully.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,477
    71
    Newcastle
    +81
    Ryan you will notice there are no Frequencies over 80 switch on.
    The LFE is set to 80.
    How would you have gone about taming the origional plot?
    Apoc, look forward to your results
  7. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    BFD II
    Meant to place some basic hints and tips but forgot so I'll do it here.
    1, A dip or peak that cover 2 squares on the graph is roughly a bandwidth of 10, if you use that as a guide you'll get some idea of what bandwidth to use in the future.
    2, If you use a positive Gain you have to redo the peak limit in the bypass mode again as boosts increase the BFD's output. Or even easier just reduce the Amp/Processor's LFE level by however much you think is needed
    3, Don't get stressed over getting a perfect curve, you will not notice minor troughs and peaks in the real world (minor = below 3Db)
    4, Many people suffer from a dip near the 80Hz frequency, this is due to the Xover and not much can be done about it with a BFD, equally the sub has less influence near 80Hz and would probably be unable to cure a huge peak at or near 80Hz (assuming you have a 80Hz Xover)
    5, Positive Gains are to be used sparingly, the more power your sub has the more you can get away with..............within reason
    Phil
  8. sticker
    sticker
    Jan 14, 2003
    1,152
    36
    Sydney, Australia
    Phil,
    I see the bath mat is still present & correct :D :D
    Regards
    John
  9. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    LOL, I knew there was something I should of done before taking the pictures, the BFD is now in a proper rack though so I'm only half an idiot :laugh:
