BFD LEDS Query
Discussion in 'Subwoofers' started by Buckster, May 7, 2007.
  1. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    Got a query please thats been bugging me for ages
    some of the filter selections (ie the 1-14 or whatever they are - the main filters not the individual ones you set within the filters if that makes sense)
    when selecting some of them 1 or 2 LEDs may be solidly lit which indicates that filters are selected with them that have either a +ve or -ve gain.
    BUT - some of my overall filters - when selected give a complete horizontal row of - for both Left and Right channels flashing LEDS. Can't seem to stop them flashing either.
    Any ideas please ? Just read through the manual and find no mention to flashing LEDs.
    thanks, Mark.
  2. Druboo
    Druboo
    Apr 1, 2006
    882
    46
    Cotswolds
    +130
    If you're on about the pre-sets??? ..... So does mine :rotfl:
    However, as I only use pre-set 4 and 5 at present it doesn't bother me :rolleyes:
    Have a read of the BFD Guide it tells you how to copy one pre-set to another :smashin:
  3. Nimby
    Nimby
    Jan 27, 2004
    9,246
    The Danish Bacon Factory
    +700
    You have your filters set to AU instead of PA. :)
  4. Druboo
    Druboo
    Apr 1, 2006
    882
    46
    Cotswolds
    +130
    Just changed pre-set 3 from AU to PA and the filters still flash :eek:
  5. Nimby
    Nimby
    Jan 27, 2004
    9,246
    +700
    Check whether you have a cut or boost on your filter and whether you have stored.
    If I change from AU to PA without doing anything else I find it cancels to show 0dB.
    The stored button should not be flashing if you have stored a real gain or cut.
    Start from the beginning of the button sequence and Filter Select then PA then go on to select Frequency, Bandwidth and finally double click on Store.
    I made a habit from the very start to run through the entire manual button sequence each time I set (or change) a filter to avoid errors. It quickly becomes automatic if you do it often enough.
    In fact I don't ever remember seeing flashing filter lights until I deliberately set to SI or AU last night to see what was happening to your BFD.
    I presume you are setting your filters manually and not via MIDI?
  6. AngelEyes
    AngelEyes
    Mar 23, 2004
    10,617
    Detached from reality
    +1,635
    I had this a few times and couldn't work out why. I just chose another preset and entered the filters from scratch and it worked fine. Would be nice to know what I did wrong though :)
  7. Druboo
    Druboo
    Apr 1, 2006
    882
    46
    Cotswolds
    +130
    Thanks Nimby :smashin:
    I was of the (mis)understanding that the filter mode, once stored changed the whole of the pre-set and not just the individual filter.
