Bfd input level
Discussion in 'Subwoofers' started by bob1, Dec 30, 2004.
  1. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    What kind of input level do you get on your bfd ,the sub out on the amp is set at +3db but doesn't do much on the led input on the bfd.The reason i ask is that i found out this morning that too low a input on the bfd is a bad thing.
    What sort of input level are other people getting.
  2. recruit
    recruit
    Bob - My output level is set at 0db which i have found is the best level to set at as if it goes higher when listening at say -4db it goes very briefly into the Red which is more or less the max output i want to go to.
    John
  3. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    I have never had it to clipping on the bfd , i think the amp as a weak output as i allways suffer with auto on on subs.
    I have turned the amp upto +6db and turned the sub down, i never play it too loud but i did try at -5db and it just started to flicker the red light.
    Just goes to show the difference in output levels between amps.
