BFD help please
Discussion in 'Subwoofers' started by Rip, Apr 7, 2005.
  1. Rip
    Rip
    Aug 30, 2004
    447
    Trowbridge
    +17
    Hi, got my BFD at last, but can you experts tell me what adaptors i will need to connect the phono ends of my cable to the BFD, & also what is the best way to go about setting my sub up, i have already got the sinewaves downloaded & on a disc & have done a trial run & have got a graph showing my peaks ect without the BFD, so im raring to go........... :thumbsup:
  2. recruit
    recruit
  3. stevej
    stevej
    May 21, 2003
    197
    2
    +3
    The only bit of advice I can give is to work at your response graph one peak or trough at a time, taking readings after you apply each filter. It's quite surprising how a filter at a specfic frequency interacts with the frequencies on either side. Once you get it right you're going to be pretty surprised at the result, but as it's already been said, it's a really steep learning curve.
    Happy tweaking :thumbsup:
    Steve
  4. Rip
    Rip
    Aug 30, 2004
    447
    Trowbridge
    +17
    Thanks guys :thumbsup:
