Not looking for help but just wanted to flag an issue should others be thinking about the same.
I recently wanted to upgrade my cinema speaker setup with a view to it being sorted for a good while. I would have gone for 11.1 but due to placement of windows was really limited to a single surround back so effectively 10.1.
I diligently read all the manuals for the receivers I was interested in and finally chose a Pioneer LX87. The manual clearly states that using a single rear is supported.
The manual also documents a configuration limitation, specifically that the amp won't drive wides and heights at the same time.
However the issue I and some folks in the US have hit is that if you have a single rear the amp will cut off all rear sound if you try to drive heights or wides. To me it's crazy if you have a pure 7.1 movie to drop the rear speaker in favour of the less useful heights or wides so effectively wides and heights are unusable.
Pioneer's response if basically tough and that's how it works. When I suggested this should be documented (like the wides and heights restriction) their helpful comment was that the receiver doesn't make toast and that's not documented either ! So 0 points to Pioneer support. Peter Tyson where the amp was purchased from were good enough to offer to take the amp back with a restocking fee which is an option.
So just wanted to warn anybody who was thinking of doing the same. Single rear in large setup = bad idea.
