Betty02's - Bedroom Cinema!
Discussion in 'Home Cinema Building DIY' started by betty02, Sep 11, 2007.
  1. betty02
    betty02
    Jun 2, 2007
    92
    11
    Well well well hi guys, it officially started as of yesterday my [-]home[/-] Bedroom Cinema, Well only being 18 still living with parents i wasn't able to do anything to a huge scale anways,
    Firt of was the overall look of the room i gave it some new furniture first of, as it was going to be a bedroom mroe then my cinema, so i got some ncie new furniture,
    As you can see from the pictures below i currently have a 32" CRt crapper, and normal freeview box (please note i can;t get full scalle operations as of my money and my parents so cnt exactly go drilling around haha)
    Andways were the tv currently is all the is going to be gone, and i cant afford a 42" as of yet, so im getting my projector mounted on the back wall (picture below) and pointing it into the gap etween the wardrobe and the boiler cabinet, i plan on using that for my TV as of now, until next few months i get a wall mounted 42" LCD, then i shall be installing a pull down screen for my projectore, now im hopefully getting a harmon 5.1 surround sound system very shortly and my projectore is being ordered today, the room has black out suede curtains for when i need them shut, and my projectore is 2200 lumens so will be good for the day, also projects at 1080 which is also a bonus, well sorry for not much of an 'AV' thread so far but you get the jist
    Thanks! The pictures are crap quality and make the room look small, couldn't find my digi cam in all the junk
    Before
    [​IMG]
    [​IMG]
    [​IMG]
    Picture of wii charging station lit up in day light with curtains closed to show you how much they black out light
    [​IMG]
    After Day 1
    [​IMG]
    Current AV Stuff - no laghing
    [​IMG]
    [​IMG]
    back wall i plan on mounting projector on free floating shelf, run trunking down to floor? - Sorry about the dog being asleep didnt have time to make bed
    [​IMG]
    [​IMG]
    Black-out Curtains - Brown Suede
    [​IMG]
  2. cybrey
    cybrey
    Apr 21, 2005
    572
    +64
    Looks interesting .. all ways fun to find out what people can manage to accomplish whilst still living with parents... incidentally is the wardrobe in its final position, the gap between it and the other thing looks very small.
  3. betty02
    betty02
    Jun 2, 2007
    92
    11
    Cheers, yeah its in final position, the pics are rubbish theres a good 3-4 foot gap between there which is a ncie good zsize until i can get a i, and then a motorized screen will be mouted to drop down infront of LCD and half the wardrobe
  4. betty02
    betty02
    Jun 2, 2007
    92
    11
    Ok all quick update for tonight purchased my projector, being sent tommorow, it cost me £240 all in, few pics and specs, should be here in time for RWC game (come onnnn)
    Pics
    [​IMG]
    [​IMG]
    Specs
    Key Features
    Type LCD Projectors
    Image Brightness 1600 ANSI lumens
    Contrast Ratio 600:1
    Platform Mac, PC
    Form Factor Portable
    Native Resolution 1024 x 768
    Max Resolution (Interpolated) 1600 x 1200 (UXGA)
    Image Size (Diagonal) 20.87 in. - 300 in.
    Image Aspect Ratio 4:3 (Standard)
    HDTV Formats 1080i, 720p
    Screen Distance 2.3 ft. - 36.09 ft.
    Synchronization Range Horizontal 15 - 100 kHz
    Synchronization Range Vertical 50 - 120 Hz
    Analog Video Format NTSC, NTSC 4.43, PAL, PAL 60, PAL-M, PAL-N, SECAM
    Technical Features
    Audio Output 3.5 mm Mini Jack, Speaker(s)
    Operation Noise 25 dB
    Interfaces
    Interface Serial (RS232)
    Video Input 4 Pin - Mini DIN (S-Video), Component Video
    Lamp
    Light Source Life 4000 Hours
    Other Features
    Speakers Output 1 W
    Special Features Keystone Correction, On Screen Menu
    Dimensions
    Height 11.2 cm
    Depth 25.8 cm
    Width 30.9 cm
    Weight 2.8 kg
    Miscellaneous
    MPN 50029520
  5. betty02
    betty02
    Jun 2, 2007
    92
    11
    Hi all well another update got my speakers today, i bought them of Greg of here, heres a few pics, on is slighty damaged but the way im mountingyou wont be able to see the damage, theres a total of 7 speakers, probs just be running 5 for now and then expand in the very near future
    Well heres the speaks ive got
    4 x MX1,
    2 x MX2
    1 x MXC
    This is just a bedroom set-up so these are more then perfect!!
    and some pictures!
    MX 2's
    Pretty much exactly the same as the MX's below!
    MX1's
    [​IMG]
    MXC's
    [​IMG]
    Well stuff should star ariving soon, as im not able to actually cut holes in walls etc i have a few plans on hiding the wires so whatch this space people!
  6. Example
    Example
    Dec 1, 2006
    65
    11
    Heartache Avenue
    +9
    Could you please tell me the model number of the projector and where you got it from?
    TIA :)
  7. betty02
    betty02
    Jun 2, 2007
    92
    11
    Sure matey its an NEC MultiSync VT58, and got it from a guy on ebay his anme is antony1629 he said he ahd 2 in his listing so not sure if they both gone or not, from the specs they look like good little projectors you after one?
  8. Example
    Example
    Dec 1, 2006
    65
    11
    Heartache Avenue
    +9
    cheers m8 be having a look now :smashin:
    looks like he aint got none left thanks anyway tho.
  9. betty02
    betty02
    Jun 2, 2007
    92
    11
    NP matey keep checking!
    Hey all well things started arriving today got a few snap shots
    Projector
    [​IMG]
    Testing Projector Images are alot better in person i juust ot a crap camera
    [​IMG]
    [​IMG]
    [​IMG]
    Projector Currently Sitting Here until speakers and amp arrive
    [​IMG]
    Verilight Remote Switch
    [​IMG]
    Remote Colelction So Far
    [​IMG]
