Better PQ - Sky or Freeview
Discussion in 'Plasma TVs Forum' started by goon525, Jul 9, 2005.
  1. goon525
    goon525
    Jul 8, 2005
    24
    3
    Now I've gone ahead and ordered my Panny TH42PV500 - quick question while I wait for it to arrive, for those who already have one (or similar), and subscribe to Sky. On the standard channels - BBC1, ITV etc, which do you think gives the better picture and sound, Sky or Freeview?
    Goon525
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    sky for sure but i think ntl out performs sky for pq.
  3. av2diefor
    av2diefor
    Depends on location for signal, generally freeview takes some beating for pq,its amazing on my panny.
  4. goon525
    goon525
    Jul 8, 2005
    24
    3
    Signal's good here in Guildford (except C5). I've not used Freeview before but I don't expect signal problems.
    I've also had ntl in the past, and wouldn't say it was better than Sky.
  5. simon33
    simon33
    I'd definetly choose Freeview over Sky.
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    just did a check and apparently we cant get freeview over in cranleigh
  7. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,548
    worthing
    +137
    apparantly we cant get it on my post code. got a freeview box anyway and signal strength is good
  8. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    really?..maybe its worth a go..its only a few quid anyway
  9. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    im in shamley green and i used to have it on a really dirt cheap box with the aerial a newish aerial but not sure if its designed for freeview. It worked, some channels quite blocky eg music channels. itv teletext didnt work but i wouldnt be surprised if this was all the box as i stole it off a mate!
    it was really small, like a semi circle about 5 inches diameter.
    In conclusion to my slightly cryptic (slightly intoxicated) post, it worked but not perfectly!
  10. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i was talking about the freeview box as well before anyone reads too much in to that!
  11. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    Freeview either works or it doesn't. The blockiness is caused by either a poor [low bitrate] output signal which is apparent on "minor" channels, or by ocassional interference such as a hoover or such like. If you discount the electrical interference [hoover] then a freeview signal will not alter like analogue does. You either get a signal the same as everyone else, or you get a red dot on the screen meaning no signal recieved.
  12. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The blockiness is poor signal. You might well be able to cure it with a new aerial. I had to have a new one as my Ch5 mux used to do this in the evenings, along with clicking and stuttering sound.
  13. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,423
    Somewhere in South Yorkshire
    +5,823
    ....and back to the original question: assuming you get glitch-free reception, then I believe, for the quoted channels, there is less digtal compression/more bandwidth/less artefacts/better picture on Freeview than on $ky.
  14. av2diefor
    av2diefor
    Absolutely.
    Another point while sky varies in pq on different channels, freeview stays consistent accross the board.
    On the sound issue sky has it beat hands down, but only if you have an amp and make use of the 5.1 dd signal on a + box :)
  15. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    And how many programs are broadcast in 5.1?
  16. av2diefor
    av2diefor
    Enough to edge it!
  17. carlton
    carlton
    Yep I gave up my sky before i got my pv500 so i use freeview(signal strength 9).Its generally very good for instance both golf and formula 1 today look so sweet i sure they hd.Shows from the seventies and that type can look the worse on the pv500 though and i tend to not watch them.Anything else is pretty good such as the bbc's,hits,tmf,news channels,discovery and history all nice.
    So to sum up i wouldnt touch sky now till they release the hd box.
  18. goon525
    goon525
    Jul 8, 2005
    24
    3
    Thanks everyone. It lookos like Freeview will have the edge. I'm not worried about 5.1 sound though I do use a high-end two channel system. But I won't be cancelling my $ky sub - watch too much sport for that!
    Goon 525
  19. Hotshot147
    Hotshot147
    Feb 22, 2005
    96
    +4
    My sky picture is very good with the pv500. :thumbsup:
  20. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    186
    Most of Sky Movies 1 + 2 are broadcast in 5.1
  21. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That must be in the evenings, the stuff in the daytime I find it hard to get a 5.1 movie to show the client.
  22. waran
    waran
    Jun 21, 2005
    80
    +4
    I thought that with a digital signal you either got a picture or not. I did not think that a better antenna would improve the picture quality, but then I could be wrong.
  23. carlton
    carlton
    If u have a poor signal u can loose information,resulting in blockiness.If u lose a few 1's and 0's hitting your aerial its not going to be a happy picture :(
  24. waran
    waran
    Jun 21, 2005
    80
    +4
    I had better go and get a better arial then as I may be losing a few 1's and 0's.
  25. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Sounds like you are, if you have a spot of picture breakup.
  26. waran
    waran
    Jun 21, 2005
    80
    +4
    not picture break up, but a lack of sharpness
  27. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Lack of sharpness?
    Well my FV pictures are all fine everything is RGB and all 3 are decent quality
  28. Artie Fufkin
    Artie Fufkin
    Aug 11, 2004
    1,607
    Aberdeenshire
    +181
    Well, that's what I thought too [and it's borne out of my experience], but others here [with more experience] seem to disagree and I can accept that.
    However, I can't see how a general lack of sharpness woud be caused by a poor signal/arial.
  29. waran
    waran
    Jun 21, 2005
    80
    +4
    I must have realy drunk on Sunday or my PV500 is improving with use, because I was watching my FV channels last night and the picture quality was brilliant.
    Is it possible to get remove the logos on the DVB channels, ie the ITV2, E4, etc logos.
  30. thornton
    thornton
    Apr 18, 2005
    263
    +10
    SKY MASSIVELY better than Freeview overall, though once in a while t'other way round if SKY are not using much bandwidth.
