Better Picture Quality
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Steca, Jun 8, 2003.
  1. Steca
    Steca
    Oct 31, 2002
    155
    +36
    I have connected up sky in bedroom but the picture is good apart from a few lines in the middle of the screen which keeps flickering. Is there any way to improve the picture IM using the sky TV link. thanks
  2. Fernsehman
    Fernsehman
    Disconnect the TV Link and see if the picture improves. Unlikely but easy to try. The TV Link simply sends the remote control, signals back to the Digibox.
    If that doesn't help then you've probably got a problem with the cable (you must use double-shielded for best results) or you've used a wall plate, splitter or cable connection.
    Failing that, you may need to amplify the signal - but that's a last resort. Sort out the cable first.
    Fman
  3. Steca
    Steca
    Oct 31, 2002
    155
    +36
    Thanks i try that.
