Better pic quality on SD Tv With Sky HD Simple YES Or NO
Discussion in 'Sky Digital TV Forum' started by ubot, Sep 12, 2007.
  1. ubot
    ubot
    Sep 12, 2007
    74
  2. speedway
    speedway
    Sep 13, 2005
    53
    +3
    Yes and NO
    You don't really expect it to be that simple really.
  3. cliveg
    cliveg
    Nov 8, 2002
    379
    Hampshire
    +11
  4. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Does the SD telly have a digital input?
    If not then it's analogue RGB scart so no real difference for the hundreds of SD channels however the HD channels should produce a better picture than their SD counterparts as they are broadcast at a higher quality to begin with and downscale fairly well.
  5. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    yes
  6. synner
    synner
    Nov 13, 2004
    24
    yes !
    Bri
  7. tonkie
    tonkie
    May 16, 2005
    3,686
    Guernsey
    +897
    Simple answer, Yes
  8. kissinuk
    kissinuk
    Jul 21, 2006
    19
    3
    +3
    SD picture quality on our old Pace box (not even Sky+) looks great on our Panasonic 42px70 (via RGB scart). I'd be very surprised if SD on the HD box was any better.
  9. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    well if you get an HD box you wil be surprised:)
  10. anticlaus105
    anticlaus105
    Nov 11, 2004
    1,112
    63
    +165
    Before anyone mentioned it, when I first changed to HD I noticed an improvement in SD channel picture quality.
    BBC seems to have very good SD quality. The diff between SKY movies HD amd SD is very noticable (depending on film). Some of the HD stuff on the BBC has been comparible to to the SD stuff tho with the exception of the footy and both have looked very good.
    Some low bitrate channels are just as [email protected] tho.
    EDIT: Guess that would class as a YES
  11. daps
    daps
    Sep 27, 2003
    Cambridgeshire
    Yes
  12. erniebert1
    erniebert1
    Jan 11, 2007
    930
    46
    +120
  13. stevos
    stevos
    May 16, 2004
    6,192
    +585
    It seems to depend on the channel/show. If your not after HD then don't bother, any difference is marginal.
    If you are only after SD then you will get a much better improvement by investing in a scaler.
  14. oasismark
    oasismark
    Jun 1, 2006
    13,679
    Sheffield
    +3,714
    Yes.
    depends on channel, but generally, SD pictures are alot better.
  15. Bachstrad
    Bachstrad
    Sep 4, 2006
    4,077
    Bristol
    +262
    Yes (via HDMI)
    ATB
    Max
  16. supermac
    supermac
    Jun 24, 2007
    226
    28
    +50
  17. GeoffWork
    GeoffWork
    Apr 10, 2006
    243
    +12
  18. nickeddle
    nickeddle
    Feb 2, 2005
    352
    North Yorks Moors National Park
    +10
    Yes via HDMI
  19. coops233
    coops233
    Oct 20, 2005
    899
    Milton Keynes
    +50
    Yes via HDMI.
    Reason
    Good components - hence the £300 price tag.
    As the saying goes - you pay for what you get.
  20. sausage47
    sausage47
    Dec 16, 2006
    53
    yes
  21. KenjohnB
    KenjohnB
    Feb 13, 2007
    648
    28
    +70
    Yes (I think!).
    Ken
  22. Chris4Koi
    Chris4Koi
    Oct 5, 2006
    249
    2
    Wells, Somerset
    +10
    Yes, better via HDMI:D
  23. chief barker
    chief barker
    Mar 26, 2005
    1,905
    3
    116
    +950
    But does HDMI offer better picture quality compared to Component?.
    I read somewhere in this forum that it doesn't.
  24. BlueAstra
    BlueAstra
    May 18, 2005
    46
    Oldham
    Yes, though some channels better than others. Not sure if the overall improvement is due to the HDMI connection, or just better internal processing.
  25. stumpywalnut
    stumpywalnut
    No.
    HD channels lovely - but SD stuff on old box was better.
  26. WATTS
    WATTS
    Mar 16, 2007
    863
    Black Ops
    +50
    Well possibly on some of the lower bitrate SD channels i say its worse on the HD box but on the higher bitrate SD channels its about same/better.
    However i did jump up to a 50" widescreen from a smaller TV so knowing that its not an ideal comparison if i had compared SD on HD box through my old TV i used to base these findings on.
    I will never know now...
  27. McFaber
    McFaber
    Aug 23, 2006
    2,197
    +144
    I don't really see any different between HDMI & component...:(
    I see a fraction(small) more depth in pictures on HDMI....
    although I think component is smoother, must be an analogue thing:rolleyes:...
    I'm really splitting hairs btw.
    Yes to the OP's question btw.
  28. gruber
    gruber
    May 14, 2006
    101
    16
    bristol
  29. tiresias
    tiresias
    Sep 2, 2006
    348
    Leeds
    +33
    I've also read this, and attributed to the fact that the deinterlacing in the HD box is not great and won't allow you to output an interlaced signal for SD over HDMI, only component.
  30. Mike K
    Mike K
    Oct 22, 2006
    61
    Somerset
    +7
