better componnet cables?
Discussion in 'Cables & Switches' started by GalacticaActual, Aug 27, 2004.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,827
    Galactica C.I.C.
    +272
    Hi there.
    I have a jvc componnet cable 3phono to three phono connecting my new plasma to my pioneer 757ai. My question is will I see a difference in picture quality on the plasma if I get a more expensive cable, Ie qed or thor. Can any one help? the jvc was only £9.99 from currys.
    Thanks.
    Dave.
  2. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    I was using the same component cables before upgrading to Mark Grant cables (from the powerbuys section). I found Marks cables gave a definite improvment to the picture. Most noticeable using test patterns, but regular TV/DVDs look cleaner than with the JVC cables. For me, worth the price.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    I would be very surprised if you did not see a large improvement on replaceing the component cables with a Mark Grant or similar.
    I origionally had a £30 component cable that I bought with my DVD player (then a Toshiba SD-900e) and replaced it with a very similar cable to the Mark Grant one. Now I am partially sighted and had problems with seeing the highlighted areas on DVD menus, but after the upgrade these stood out clearly. So with my poor eye sight it was well worth the upgrade, so if your sight is fairly good you should IMO see even more of an improvement.
    Mark.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,213
    The Borders
    +2,931
    Hello Dave
    Obviously very biased at this end but so far no one has taken us up on the offer of a full refund if they didn't see a difference when upgrading to the BetterCables Silver Serpent Component Video cables we supply.
    I'd also suggest a copy of AVIA or DVE tune up DVD's from the Power Buy section if you havened already invested in one.
    Best regards
    Joe
