Better Component cable = Better picture?
Discussion in 'Cables & Switches' started by weyland-yutani, Sep 22, 2005.
  1. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    i've got a standard set of profigold component cables (£25). would my picture improve if i bought a more expensive set of cables (£50) or is all a load of stuff and nonsense? :)
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,311
    Rainham Essex
    +2,425
    IMO better cables do improve PQ! I upgraded my component cables that were bundled with a DVD player (no idea what they were as there was no writing on them) to cables the same as those sold by Mark Grant. They were fairly cheap compared to some of the well known brand cables, but the increase in detail with more vivid colours really surprised me.
    I suggest you take a look at the Mark Grant cables in the cable power buy section as they are fairly cheap, but I think you would need to spend a lot more money to beat their performance.
    Mark.
  3. chrisw
    chrisw
    May 20, 2004
    2,411
    83
    Maidenhead
    +262
    I changed my £10 unbranded component (from ebay) cable to a QED £80 cable and the difference is very noticeable.
    I currently watch sky through my DVD recorder via component (this will change in the next week to scart probably) and the improvment in PQ was slight, but watching DVDs, the PQ is 5x better at least. Everything is much sharper, the lines, the colours the motion - just all seems cleaner and crisper.
    So yes, may be worth it - and if you don't like it, you can always sell them here!
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,549
    The Borders
    +3,024
    weyland-yutani
    If your current 75ohm cables are not built to a decent spec/performance then yes replacing them with a better spec/performance cable may cause less signal degradation.
    Simply heading in the direction of a £50.00 cable set is no guarantee your going to get an improvement - look at what Mark Grant, VanDamme and manufacturers who state specifications offer and see how those £50.00 cables compare before you splash out on them.
    Here's a link to a very decent cable (currently on offer at a very favourable price) with some info on the important tech specs - http://www.bettercables.com/silserrefcom.html
    Best regards
    Joe
  5. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    5,985
    2
    2
    Bromsgrove
    +584
    I noticed differences between cables... but you don't have to shell out a load of cash. The Mark Grant ones look excellent value but i've not tried them.
    http://www.avforums.com/forums/showthread.php?t=241589&page=2
    My post second from the bottom is a brief review of an Acoustic Research cable i bought, and it's excellent. Cost £29.99 + £4 postage.
  6. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    thanks guys, i may give the mark gant 1m component a go.
  7. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Good choice but beware they are very very chunky,if space is an issue check the specs first.Approx 30mm diameter cable.Not very bendable either.
  8. weyland-yutani
    weyland-yutani
    Jan 11, 2002
    1,783
    +104
    yeah, but the end cables are thin aren't they?
  9. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    a couple of 99p audio cables will do fine.
  10. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    how have you connected your sky box to dvd???
  11. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    can you scart sky box to dvd and then connect dvd via component and still get your sky signal,i have tried this with my system and could not get it to work,for one when compnent is switched on the scart rgb has to be turned off, does this sound right???
  12. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    You can't do this, RGB pass through is possible but I don't know of any RGB to component conversions in DVD players.
  13. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    The 7710A is about 20mm diameter, not 30mm :)
    Reasonably flexible for its size !
    For more flexible component cables, 3 lengths of Belden 1694A are ideal,
    as seen
    here
    Mark.
  14. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    Thanks for your answer, i did not think this could be done
  15. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    My Philips DVDR80 has an rgb scart to component conversion thing.
  16. Troon
    Troon
    Apr 28, 2005
    151
    Not for video.
    I'm usually a cable sceptic, but once you're up in the video frequencies, construction and shielding start to make a real difference.
  17. demostenes
    demostenes
    Considering space a problem what do u think of the IXOS component cables?
    Being so thin how are they in terms of shielding?
