Better cable for Plasma
Discussion in 'Cables & Switches' started by Paul97, Nov 7, 2004.
  1. Paul97
    Paul97
    Jan 20, 2004
    622
    Hartlepool
    +23
    Can anyone tell me if there is a better cable for my Hitachi 42PD3000 Plasma Tv, you will have to bear with me as I don't know the correct name for it. I think it relays the picture from my Seperate tuner box to the screen, it is a dual cable but the connections are different on each length. Hope you can understand what I mean. :confused:
    Thanks all
  2. bobbypunk
    bobbypunk
    it is possible to replace it but it's unlikely you'll find a "better" version.
  3. Paul97
    Paul97
    Jan 20, 2004
    622
    Hartlepool
    +23
    Thanks Bobbypunk
