D
Deleted member 765458
IMPORTANT!
– Please do not mix up with just additional boot from sd card, this is real dual boot firmware where you can switch the system using power menu.
– This update will not come via OTA automatically. You need manually install this update in order to use it. Using release candidate firmware you still will be able to update your device via OTA, if you want to continue using automatic stable updates.
– This is BETA release, so if you want the system update automatically, you need to wait Dual Boot build based on stable firmware.
– So if you are totally ok with your current system and you are waiting for next stable firmware, you can pass this topic.
– This dual boot version built on Release candidate firmware, so it may cause to some bugs appeared. You can help us to track bugs and issues of a current build, we appreciate your help. "
IMPORTANT!
Beta Dual Boot Firmware v.0.2.8+ CoreElec for Ugoos AM6/AM6 Pro & X2/X3 Series «
chinagadgetsreviews.com
