Best XBox Wireless Controller
Discussion in 'Xbox Forums' started by bbasra, Nov 24, 2004.
  1. bbasra
    bbasra
    Sep 15, 2004
    1,622
    48
    Hounslow
    +41
    Can you please tell me which is the best XBox Wireless Controller to go for.
    I am looking for range, battery and something that does not interfere with Wireless Networks, Bluetooth, Digital Cordless Phone and a wireless TV Sender.
    Thanks In advance.
  2. john2303
    john2303
    Jul 2, 2004
    285
    Aberdeenshire
    +8
    I have the Joytech Neo S Wireless controller.
    I got it off play.com and it works really well also it only costs £18
    cheers
    john
  3. johnnyhonk
    johnnyhonk
    I have 2 of the Logitech ones.
    Range is superb. I can be at the other end of the house and it still works. Runs on a couple of 'included' AA batteries, which haven't run out, although both have only been in my possession for about 3 months.
    Having used cordless stuff before, I was aprehensive as normally cordless stuff never matches up to the wired equivalent, but these are really good. Cost me $80 AU each.
    I have a 2.4Ghz phone as well, and wireless network, and neither the phone, network or the controllers seem to conflict when they're all running. :smashin:
    Its all good in the neighborhood. :thumbsup:
  4. bbasra
    bbasra
    Sep 15, 2004
    1,622
    48
    Hounslow
    +41
    Can i use my live headset with the Joytech and logtech ones?
  5. srm
    srm
    Another vote for the logitech.
    They are build well and have no lag. :thumbsup:
    I couldn't be happier them.
    bbasra: no you can't use your live headset.
    (but i think the logitech are releasing a wireless headset to use for xbox live)
    regards,
    Stephen.
  6. Messiah
    Messiah
    Apr 22, 2002
    7,543
    +338
    Check here :smashin:
  7. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Wheres the best place to get the logitechs?
  8. Messiah
    Messiah
    Apr 22, 2002
    7,543
    +338
