Best XBOX S-Video Lead?
Discussion in 'Xbox Forums' started by GJD, Nov 22, 2004.
  1. GJD
    GJD
    Sep 23, 2002
    282
    Just got myself an LCD TV which has DVI/Component & S-Video inputs, as well as composite. The XBOX picture quality (PAL, unmodded) looks cruddy via composite so I was wondering which S-Video cable you guys would recommend (I've seen Joytech, Monster, Saitek etc on sale)... I'd consider component (and the HiDEF soft mod for unmodded UK XBOXes) but the component input will have a prog scan DVD player plugged into it when I get round to buying one! ... UNLESS there's some sort of component switch box you guys would recommend..
    Any help much welcome..
  2. pemberto
    pemberto
    Oct 14, 2003
    500
    28
    Huntingdon
    +32
    The Monster S-Video has great build quality and at 10ft long should give you plenty of cable to play with.
  3. johnnyhonk
    johnnyhonk
    I can't say that I recommend a particular switchbox (maybe someone else can), but do yourself a favor and get one and run component. Its that good.
    I have the MS S-Video Pack and the Green Monster Xbox S-Video Cable, but both are rubbish compared to HiDef Component.
  4. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    Cant you put them through your amp just a thought!
  5. GJD
    GJD
    Sep 23, 2002
    282
    Is component still the way to go if I don't mod my UK XBOX? I understand it won't give me HD unless I do (either soft or hard mod)..BUT will the picture quality or resolution on an umodded pal XBOX still be better with component than with S-VIDEO?
    I picked up an S-video leas in GAME today. Only a fiver but the quality doesn't look any better than the bundled composite leads. You get what you pay for I suppose.. Can't seem to track down the Monster (or IXOS or Saitek) S-Video leads in the UK.. Anyone have any ideas where I can get one (pref the Monster one).. Gotta be better than the picture quality I'm getting at the moment..
  6. Jamiroquai78
    Jamiroquai78
