Best with set-top boxes – Tosh XS34 or Pany EH50?
Discussion in 'Blu-ray & DVD Players & Recorders' started by howardmg, Apr 6, 2005.
  1. howardmg
    howardmg
    Sep 13, 2004
    123
    Kingston, Surrey
    I’m reliant on cable as my aerial reception is no good, and therefore no point in me waiting for HDD DVDs with Freeview later in year (luckily).
    I understand that the Tosh is good in controlling set-top boxes and sounds like a great machine from what I’ve read here.
    But before I make the plunge are there any significant disadvantages v the new Panasonic EH50?
    These things come to mind after reading about the Panasonic in What Video this month:-
    - It can play +R discs – can the Toshiba?
    - Quick start up time of one second – how does the Tosh compare if you keep it on the whole time?
    - New 500 line resolution on the LP mode allowing a 3 hour film on one disc
    - High speed HDD -> DVD dub
    Appreciate any feedback…
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Toshiba XS32 (and I believe XS34) won't play +R discs. (unless they were burned with a DVD-ROM booktype).
    Doesn't start in one second from off - more like 10-15 seconds. If it is on, it starts immediately.
    Full (500 line) resolution up to 2 hours 20 mins... for 3 hours would use half resolution. Picture still pretty good; I can't say how it compares to the new Pannys.
    It does high speed HDD > DVD DUB. On -R it is 4x, on -RW it is 2x.
    Mark
  3. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,121
    116
    +908
    I'm trying to make the same decision - but I'm also throwing the Panny E95 into the mix.
    The Panny EH50 has a 12bit D/A converter which is supposed to improve playback picture quality compared to the 10bit E95 and Toshiba. I have seen posts from people who have used the Tosh 32/34 that state that Panny's are more user friendly. Also a couple of posts complaining about the 34s fan noise. The main advantage for me of the Tosh is its DV input. That is why I am also considering the Panny E95.
  4. howardmg
    howardmg
    Sep 13, 2004
    123
    Kingston, Surrey
    Thanks to both of you for the feedback - would a Dell NEC +R/+RW drive count as a "DVD-ROM booktype"?
    New Pannys claim 4 hours at 500 line resolution.
    I was heading for the Toshiba XS34 but there seem to be a number of disadvantages:-
    - noisy fan
    - -R software issues
    - unlikely to play +R
    - no external link to STB (need redeye tool to get IR to control Telewest Pace STB I think)
    One, probably stupid, question on DV IN - as I edit my camcorder footage via the PC, is this something I need?
  5. MikeHarrison
    MikeHarrison
    Do any of the pannys have set-top box control ?
    I would put the convenience of this for everyday use higher than any marginal details of formats and dac resolution you'll neer notice....
  6. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    To set the booktype you need a PC drive which can handle this, and also burining software that can do it. I'm not sure about your particular drive.
    If you edit your DV camcorder footage via PC (as I do), then DV in on the recorder isn't essential, but I've found it useful, when I want a quick way to record some footage.
    I don't find the fan an issue (on the XS32), but some do.
    Mark
  7. Jungle
    Jungle
    Does any one know how much is the Panny EH50. I noticed you can get a Tosh XS32 for around £300. If the Panny EH50 cost significantly more then we can't compare the mini with a BMW
  8. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Similar prices: at RGB Direct (for example), XS34 is £318, EH50 is £321. I'd go for the XS34 over a XS32, unless you can get the XS32 much cheaper. XS34 vs. EH50 is a harder call.
    Mark
  9. bossnas
    bossnas
    Jan 27, 2005
    48
    I recently had this dilemma but ended up going for the XS34 due to the DV Input and the 160GB HDD. Mine arrived yesterday so I'll have a good play with it over the weekend. Another downside of the Panny's for me is they don't record a 16:9 flag to -R, only to DVD-RAM, I think the XS34 will record the flag but I can't confirm that just yet.
    Nas
  10. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    I'm pretty sure the XS34 will, the XS32 does....
    When you create a DVD-R on the XS32, you can specify 3 values for the aspect ratio (which sets the "flag" appropriately): Either 4:3, 16:9, or "Original", which takes the value from the recording.
    I tried to check the XS34 manual to see if it works the same, but when I download the manual I only get the first 86 pages... strange... from http://tesc.toshiba.co.uk
    Mark
  11. howardmg
    howardmg
    Sep 13, 2004
    123
    Kingston, Surrey
    Can any Panasonic owners out there confirm that they can / cannot control Digiboxes?
  12. LFC4ever
    LFC4ever
    Mar 18, 2004
    444
    Henley on Thames
    +3
    My E85 can't - I bought a device that's supposed to do this via infrared but it was useless. I believe the best player to do this is the Pioneer 920 but it costs nearly £900.
