best wirless
Discussion in 'Headphones, Earphones & Portable Music' started by pinkpanther1, Sep 29, 2004.
  1. pinkpanther1
    pinkpanther1
    which ones guys please and cheapish cheers
  2. Grif
    Grif
    Jul 28, 2004
    269
    +4
    Read some good reports on Senn RS65....better than the 45 and as good as the 85....this is just what I've read, I've only heard the 65 and they sounded pretty good, until I tried some 595's. I do know that you will get better sound and probably for less money if you can put up with a cable...I was thinking about wireless but went with 595's in the end.
    BTW....this may be straight from left field, but....you don't ride a Triumph do you?
