Best way to upgrade multiple speakers?
Discussion in 'Home Cinema Speakers' started by SeeNoWeevil, Oct 21, 2003.
  1. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,695
    +873
    I expect most people, myself included can't afford to upgrade all channels at once so what is the best way to go about it?
    One thing that may be a problem is manufacturers dont make their products forever, im not sure how long the average life cycle of a speakers is or if its really a problem.
    I have all series 2 B&W's, for example would a series 3 speakers blend in well tonally with the older s2's?
    What do people mean when they talk about a tonal match, do they mean similar frequency responses? what is the actual differences between two tonally different speakers, physically speaking?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It isn't really about frequency response but about voice matching. In a surround sound environment voices and other sounds will pan across the soundstage and you don't want the voices to change halfway across as the speakers are different.
    Unfortunately I am not an expert on B&W so can't answer your specific question
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    I wouldn't say I'm an expert on B&W either,but have heard quite a few and do use them.
    I'd expect given the overall voicing of them,that you'd have little problem going with later models from the same range,or moving up a range.
    Obviously,the easiest and best way is to loan a set from your local dealer and try them in your own system before buying.
  4. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,695
    +873
    thanks guys, so you think merging in some CDM's into my current 600 S2's would sound ok?
    I'm still curious as to what voicing actually means in a technical sense?
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    In a technical sense,from a practical point of view it means very little.....what it does mean is how the speaker sounds in terms of tonal balances....bright/bass heavy/etc....
    I would have thought the CDM or 700 range would be well worth looking at,and maybe upgrade the fronts/centre first.
  6. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,695
    +873
    Surely this all boils down to a differing freq. response?
    I currently have 602's at the front, 601's at the rear and a CC6 centre. I plan to first replace the CC6 for a CDM CNT and put the CC6 in the centre rear, then replace the 602's.
