Best way to spend 2k
Discussion in 'Plasma TVs Forum' started by Bobby_Dazzler, Jan 28, 2005.
  1. Bobby_Dazzler
    Bobby_Dazzler
    Hi all
    I just dont know what to spend my money on !
    I want a PW7 and already have sky + so that leaves about 600 squid but whats the best home cinema to go for? and what convertors and or input boards will i need to get best sound and picture quality? could i get a dvd recorder in there somewhere as well?
    thanks in advance
    bobby
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. ian.webb
    ian.webb
    I’m in similar position to you 2k to spend. However, I already have a Sony App and speakers, although it a couple of years old now but still produces a good sound from both my existing Toshiba DVD and Sky+.
    I’m also considering the PW7, though I’m not sure what the difference is between TH37PW7B and the TH37PWD7 panels are.
    However, my intended purchases are as follows:-
    PW37PW7B including component board
    JS RGB to VGA Unit
    The connections are as follows, bearing in mind I only watch Sky+ & DVD’s.
    DVD Component out to PW7 Component – New Cable required
    Sky+ RGB out to JS Converter to PW7 VGA - VGA to VGA Cable required
    Sound will be taken directly from SKy+ and DVD directly in Sony Amp via Digital audio cables.
    I will be interested in a new DVD in the future as it currently doesn’t support progressive scan and a new Home Cinema system will probably make use of the Yamaha Amp so I will be interested in the responses to your request.
  4. Bobby_Dazzler
    Bobby_Dazzler
    thanks HD
    one question tho..... Im not sure if you recomended on that thread connecting to pw7 via vga or via scart?
    what do u recon?
    bobby
  5. Bobby_Dazzler
    Bobby_Dazzler
    hmmm interesting !!!
    It looks like im gonna do exactly what HD says but im just not sure wether its all via vga or scart? ??
    I will get the vsx c402-s tomorrow, if i can find one!
