Best way to set up your pj, is there a dvd with help, like Toy Story etc.
Discussion in 'Projectors, Screens & Video Processors' started by brad123, Feb 2, 2002.
  1. brad123
    brad123
    Jan 29, 2002
    3,833
    68
    West Yorkshire
    +62
    Ive heard that a few dvd films have extras wherby it helps you set up your set correctly, do these work and what films have them. I have a scart to phon lead into my pj so what needs doing to get the best picture quality.
    also there appears to be a few smears on the outside of the lens, how do i clean this.
    thanks guys
  2. calibos
    calibos
    Aug 4, 2000
    935
    Ireland
    +33
    The R2 Phantom menace and Terminator 2 have the THX optimode Sound and Screen setup. I think its only the R1 version of Toy Story that also has this.
  3. HBK757
    HBK757
    Jan 15, 2002
    153
    16
    Be a real man and buy an Avia Home Theater Calibration DVD :D
  4. Timh
    Timh
    Sep 14, 2000
    5,204
    3
    3
    Altair-4
    +298
    Be a real man and buy an s video lead ;)
  5. skimber
    skimber
    Dec 1, 2001
    205
    19
    put even more hairs on your chest and use an HCPC with dscaler!
  6. laurie
    laurie
    Nov 23, 2001
    145
    16
    Sydney Australia
    Only if you watch NTSC it is usless for PAL calibration...my 2cents worth
    cheers Laurie
  7. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,621
    7
    167
    Birmingham, UK
    +10,500
    Brad, you haven't said which projector you have.
    Using your scart to phono cable will be the worst way to connect up your projector.
    Using a scart to S-video converter will improve the picture quality.
    If your projector is up to it, using a home cinema PC connected up via RGB will produce the best results for your money. With DVD, the picture quality can be better than you see at the cinema.
    You could use a video scaler instead of a home cinema computer, but that's leading off to a more complicated story.
    Anyhow, people either use Video Essentials or the Avia disc mentioned above. You can get both from Amazon.
    Don't know about the smears issue.
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,210
    Not entirely true been covered before and it also depends on your kit but Avia or VE should be fine for setting most things regardless of PAL/NTSC issues as long as you use it the right way.
